Diagnose this-
Old Sep 13, 2007 | 03:54 PM
InTTruder's Avatar
AudiWorld Awesome User
Default Diagnose this-
I have a suspicion, but I'll wait for more experienced hands to weigh in-
- Friend picks up 2002 TT-R in Long Island and drives it home to GA
- He has fairly complte service records on car, and it is good, although TB/tensioner and WP are OE
- Drives to work, and for whatever reason idsables the ESP
- Starts car, drives 150 yards, and car stops running but will turn over
- I haven't insptected the car, but he insists (frightening) that car is making compression.
Options:
- Immobilizer failure
- TB failure
- Fuel delivery system (FPR, fuel pump)
- other "undiscovered country"?
So: the simple things are hard. Where do we start.
TIA!
Old Sep 13, 2007 | 03:59 PM
Qu!cksilva's Avatar
Junior Member
immobilizer
Old Sep 13, 2007 | 04:03 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Hmmmm...I don't think that's it..>
You usually get a start and 1/2 second of running....
Old Sep 13, 2007 | 04:09 PM
Aarononymous's Avatar
Default I'm going to say 50/50 Timing Belt-No Fuel
bad cluster is common, possible pump or level sender. A car with a stripped TB makes a distinct sound on cranking. Pull the upper TB cover back & crank to see if it's spinning. If so add a gallon of gas & try it. If no luck carefully pull back the fule pressure line off the rail to see if pressure was built up. Immobilizer causes a start stall condition, within about 2 seconds. Could be something else as well....
Old Sep 13, 2007 | 04:11 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Yup......Outta gas...>>
Assuming he has compression as he claims. Bad senders or cluster common..
Old Sep 13, 2007 | 04:49 PM
Scenic Driver's Avatar
I've had it happen and can verify that the car does run for a second and then shuts off
Old Sep 13, 2007 | 04:59 PM
InTTruder's Avatar
Claims he added fuel and got the start/stop. How do we find the Immobilizer circuit?
Old Sep 13, 2007 | 05:08 PM
msauve's Avatar
Good luck going 450 feet in a second from a cold start.
 Pouria Savadkouei
 Michael S. Palmer
Old Sep 13, 2007 | 05:09 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Dealer fix....>
Flatbed award ......:-(
Is the little Key symbol staying lit in the cluster or going out? Lit, than immobilizer.
(or try one of the other keys)
Old Sep 13, 2007 | 05:13 PM
Default I never said this problem was the immobilizer >>>
I was just confirming what happens when the immobilizer kills the car.
This sounds like a fuel problem.
