problem with coolant temp sensor change out
Old Sep 13, 2007 | 05:03 PM
abstracTT's Avatar
Default problem with coolant temp sensor change out
i pull out the sensor and its blue and doesnt match the connections that the new green one does...
the blue one ( old one ) is shorter and square where as the new green one is long.
the old assembly has a different kind of clamp.. i dont knwo what to do..
Old Sep 13, 2007 | 05:12 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Early cars used a different sender...>
The commmon Green Top one won't fit. Get the right sender. Unfortunately the square flanged one you need is more expensive..
Old Sep 13, 2007 | 05:52 PM
abstracTT's Avatar
Default Re: Early cars used a different sender...>
well that sucks... when i went to VW to get the new green one, thats what they gave..i dont see why the squared one didnt pull up when i gave the year and model.
Old Sep 13, 2007 | 07:21 PM
abstracTT's Avatar
Default the mindless wonder...
oh and btw, the genius that i am...forgot to release the pressure from the coolant resevoir. so when i pull the sensor out...whoosh!
good thing the coolant wasnt hot.
Old Sep 13, 2007 | 07:34 PM
HACK THS's Avatar
Crazy, I didn't know there was a difference, mine is a 2000 (May) and uses what everyone else uses
Old Sep 14, 2007 | 04:20 AM
diehlryan's Avatar
If we didn't make mistakes we'd never learn anything.
Old Sep 14, 2007 | 09:37 AM
M power this!'s Avatar
Default Green top visual
<center><img src="http://pictureposter.audiworld.com/50555/coolant_sensor_on_car.jpg"></center><p>
Old Sep 14, 2007 | 09:50 AM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default And the plug side....>
Note the oval shape which is different from the early Square shouldered senders..
<img src="http://images5.fotki.com/v61/photos/7/7305/776256/Picture049-vi.jpg">
 Pouria Savadkouei
 Michael S. Palmer
hellbringer
Jan 7, 2010 08:02 AM
wildaman85
Jul 23, 2005 03:52 PM
markbradford
Feb 26, 2004 08:59 AM
TTahoe
Jun 17, 2003 02:24 PM
MattKA4
Jan 7, 2003 08:06 AM
