Question for people (Blue TTop) who have installed LCR splitter.
Old Sep 13, 2007 | 07:45 PM
cabo1's Avatar
Default Question for people (Blue TTop) who have installed LCR splitter.
I'm trying to fit mine so I can install it this weekend. Blue TTop has a great write up...It says to cut about 50mm off each end of the splitter...I've only cut about 15mm off each side, but when I test fit it against the fender trim, the front of the splitter seems to be tucked extremely far back under the bumper (much farther than Blue TTop's)with only 15mm cut off and the corners still stick out too far. I was wondering if you need to bend the splitter slightly to match curvature of the bumper or do you just bolt the splitter on in its natural shape?
Old Sep 13, 2007 | 08:37 PM
Blue TTop's Avatar
Default IIRC it was a very slight bend to match the curve of the bumper. I recommend.........>>>
removing the black plastic air-dam piece at each wheel. Set the splitter into place and get it positioned exactly the way you want it. Then you can cut the ends.
<img src="http://images28.fotki.com/v965/photos/1/168597/5124433/DSC04679-vi.jpg">
Old Sep 13, 2007 | 08:43 PM
cabo1's Avatar
Thanks...I appreciate the write up.
rogman897
Jul 23, 2007 07:12 PM
S4h2j2
Auto Detailing Discussion
Apr 23, 2003 12:15 PM
MikTip
Sep 13, 2002 03:32 PM
