Normal Water Temp Gauge
Old Sep 14, 2007 | 05:13 PM
fstshrk's Avatar
New Member
Default Normal Water Temp Gauge
I noticed today the water temp gauge in my 03 TTQR reads at 1/2 mark pretty much all the time except when I am in stop-and-go traffic where it moves to roughly 1 bar higher and then moves between the 1/2 mark and 1/2+1 bar.
Is this normal?
I am a newbie TT owner (03 TTQR with 19K miles purchased less than a month ago).
So far having great fun with this car just commuting. My 04 M3 6MT w/30K miles is getting lonely in the garage ;-)
Old Sep 14, 2007 | 05:17 PM
Kareem of Elise's Avatar
Default Re: Normal Water Temp Gauge
<ul><li><a href="https://forums.audiworld.com/tt/msgs/1682991.phtml">page down</a></li></ul>
Old Sep 14, 2007 | 05:30 PM
InTTruder's Avatar
AudiWorld Awesome User
Water Pump, gauge cluster, or fan control module/fan issue.
Old Sep 14, 2007 | 05:43 PM
fstshrk's Avatar
New Member
Default Thanks, seems like it is normal.
The fan is working, I can hear it.
Old Sep 14, 2007 | 05:44 PM
There are 2 fans, you know.
Old Sep 14, 2007 | 05:51 PM
fstshrk's Avatar
New Member
Default Re: There are 2 fans, you know.
How do you check the 2nd fan turn on?
By the way, this was with the A/C set on ECO.
Will idling the car until both fans turn on, do it?
Bora
Old Sep 14, 2007 | 05:56 PM
InTTruder's Avatar
Default Turn AC on: both fans run. W/O AC, all funs should be run if ...
T &gt; 105*C.
Use the HVAC console to access block 49 and read bulk coolant temperature.
Old Sep 14, 2007 | 06:22 PM
fstshrk's Avatar
New Member
Default Re: Turn AC on: both fans run. W/O AC, all funs should be run if ...
Hi InTTruder, thanks for the info.
Is there an FAQ for this forum that shows me how to do this?
Thanks
 Pouria Savadkouei
 Michael S. Palmer
Old Sep 14, 2007 | 07:39 PM
InTTruder's Avatar
Default FAQ (sorry, I assumed)
<ul><li><a href="https://forums.audiworld.com/tt/msgs/1389261.phtml">TT FAQs</a></li></ul>
vrsexxin
Oct 13, 2009 06:15 PM
SteveIAS8
Aug 4, 2005 05:32 PM
4000skq
Nov 1, 2003 07:05 PM
DoubleA6
Apr 16, 2003 07:54 AM
petersS4
Audi Original "S" Cars
Jan 28, 2002 08:42 PM
