Ran some Vag logs for fun with stock box and VTDA.................
<img src="http://images28.fotki.com/v1002/photos/6/645139/2489087/StockBoxRun1-vi.jpg">
<img src="http://images29.fotki.com/v1016/photos/6/645139/2489087/StockBoxRun2-vi.jpg">
<img src="http://images27.fotki.com/v1018/photos/6/645139/2489087/StockBoxnoFeedScreenedRun1-vi.jpg">
<img src="http://images27.fotki.com/v990/photos/6/645139/2489087/StockBoxnoFeedScreenedRun2-vi.jpg">
<img src="http://images27.fotki.com/v1023/photos/6/645139/2489087/VTDARun1-vi.jpg">
<img src="http://images28.fotki.com/v1000/photos/6/645139/2489087/VTDARun2-vi.jpg">
The MAF Sensor was the same in each run. I wish I had logged the inlet air etc for the stock box, with the feed but I didn't think of it at the time. I also tried to keep the RPM about the same. These were all logged in first gear, the second gear readings were about the same.
BTW, the inlet air temps are probably higher for the VTDA because the engine didn't fully cool after the second group of runs. The first group was run a day or two ago.
Each data run (g/sec) will be a separate column. So when done, your work sheet headings will be:
TIME
RPM
run 1 (g/s)
run 2 (g/s)
run 3 (g/s)
etc.
You can then graph all runs on a single chart.
You did this on your driveway???? Must be pretty long.
These were all 3rd gear runs, right?
