Reverse "Pop" in Suspension ... FIX? During DEFCON install? >>>>>>>
About a month ago I replaced the front upper strut mounts and bearings, and (as I expected) this had no effect on the pop. Years ago I tried torquing subframe bolts, etc.--no change.
This weekend I installed my DEFCON 3 kit, and today I've had no pop. It might be too early to speculate, but if it's been fixed, the problem would relate to:
1. either of the two bushings themselves--the rear one was cracked/split a bit;
2. the bushing bolts not being torqued enough;
3. play in the arm-ball joint bolts (3). I didn't see any evidence of movement there, though, and my tire wear hasn't indicated anything, either.
I'm inclined to think it might relate to the torquing of the bushing bolts.
Go ahead & track this thread if you're interested and I'll post a follow up after a few more days.
I thought I'd finally bagged it with new ball joints, the passenger's was kinda "crunchy". Driver's was still smooth at 148k. I replaced both, ahhhh... silence! for awhile...
The noise returned on the run back from TT east.
Everything that can be replaced except the steering rack, has been replaced.
Yesterday I had the front end up to clean wheels, and retorqued stuff: ball joints, control arms, anti sway links, etc
nothing was loose, but it's quiet again
Yes,I know what I said "rear caliper" , but it does sound like it comes from the front. Lift your rear wheel, release the e-brake and spin the wheel backwards. . . you might be surprised.
pattreek
2001 TTQC
