on 17x8 wheels...what would be the ideal offset? (w/o spacers)
stock is 32 offset right? these wheels i'm looking at are 35 offset.
Will a 28 offset work with a 17x8 setup? 32 would be a little further out towards the fender right (considering these wheels would be a bit wider than OEM). how far can i go safely? 25mm?
i've used the offset calculator...and it helped, but i needed a more verbal assessment of the situation
I believe the quattro is around 6mm more narrow than the fwd.
you're running 25mm spacers and they're flush? what is the width of your wheels?
these are 17x8.
quote: Bill Clinton, at his impeachment...
Seriously, it does depend on your definition of ideal... perfect fitment to the fender, vs ideal suspension geometry. Spacers are required to line up the fit with the fender. Since you're emphatic about not using spacers (makes two of us), then you should go for ideal geometery (the same as stock @ et = 32). But you'll still have to use a small spacer... With an et=35 wheel, a 3mm spacer will put you to et=32. My fronts are 17x8 @ et=32. Pic shows you what you get assuming 225/45-17
but otherwise, it SHOULD be comparable to stock then.
