Knock Sensors Too Low - Int. Cont. Module Malfunction - Whoopee!!
Old Sep 27, 2007 | 07:10 PM
TTaipan's Avatar
New Member
Default Knock Sensors Too Low - Int. Cont. Module Malfunction - Whoopee!!
I am a little stumped. After replacing the temp sensor, the coolant hose flange and cleaning the fuel injectors & replacing all the injector o-rings the TT is running better and not leaking coolant anymore but... I am noticing hiccups under full throttle at high RPM's. It is throwing these codes:
P0327 16711 - Knock Sensor 1: Signal too Low
P0332 16716 - Knock Sensor 2: Signal too Low
P1386 17794 - Internal Control Module Malfunction
Every time I clear them they come right back. I disconnected the MAF on the off chance that it would improve the situation but instead I got a CEL, a code about the MAF signal being too low along with the return of the other 3 codes and the car still runs like sh#t. I also replaced the vacuum hose to the FPR since it looked like it had seen better days. No change. I have the starter hose kit from Hose Techniques and I am going to replace all the vacuum hoses this weekend. I am thinking that it is running lean...maybe a leak in a vacuum line?? A bad FPR?? Anyone seen this before?
Thank you!
Old Sep 28, 2007 | 05:47 AM
N9909E's Avatar
Junior Member
Default Uh oh - that's electrical. And it's the ECU.
Did you have your ECU chipped recently? It could be that you severed a knock sensor wire while doing the injectors, etc.
Old Sep 28, 2007 | 06:08 AM
TTaipan's Avatar
New Member
Default Stock ECU but I will double check the wiring around the injectors...
...it makes perfect sense that something might have gotten disconnected. Thank you...I don't know why I didn't think of that.
Doesn't a bad ECU usually throw a lot of other codes too??
Old Sep 28, 2007 | 06:18 AM
N9909E's Avatar
Junior Member
Default Well, mine did - but they soldered across circuits.
First thing to look at for "low Signal" is wiring to the component. I used to get it for the N75 valve until I replaced the connector and wiring.
I guess if the ECU doesn't "see" the knock sensor, the timing retards to a safe range and stays there - not good for acceleration, etc.
Old Sep 28, 2007 | 06:35 AM
N9909E's Avatar
Junior Member
Default This is from <ahem> another forum, suggesting corrosion under the sensor ...
Friday, 13 May 2005, 18:27:55
VAG-COM Version: Release 504.1-UD
Control Module Part Number: 06A 906 032 CL
Component and/or Version: 1.8l 5V 110kW TLG V003
Software Coding: 06500
Work Shop Code: WSC 00001
1 Fault Found:
16716 - Knock Sensor 2 (G66): Signal too Low
P0332 - 35-10 - - - Intermittent
______________________________________________ Re: Timing Belt replacement...hard? (ffej0427) » « » 9:01 PM 5-18-2005
Remove the sensor, clean underneath with a wire brush, fine sandpaper, steel wool, reinstall and torque to 20ft/lbs (I think).
Quattroism45
30v V6 Discussion
Jan 11, 2009 04:56 PM
einsgruber
Canadian Discussion
Jul 9, 2008 10:36 AM
2kblacks4
Apr 16, 2007 12:07 PM
Slye A4
12v V6 Discussion
Nov 17, 2006 03:25 PM
box_of_partS4
Aug 24, 2005 06:01 AM
