Going in for an alignment tomorrow. Lets discuss some choices >>>
Now here is my question- most alignment specs are for a 225 TT which is much better balanced than a 3.2TT. I currently have a 22mm rear sway and a blue Haldex controller and the car still seems to understeer at the limit (off throttle can induce a bit of rotation).
I do have the full KMAC kit in the rear ...
So how should I alter the alignment to get more neutral to mild oversteer handling? The shop asked me to get the specs I want ...
Also, no difference in spec for 1.8 vs 3.2, your numbers are what most strive for. In a lowered car, -1 degree camber in the front is hard to do, you may have to live with a little more negative camber, even with moving the subframe.
