Can I use a slightly larger diameter vacuum line for my boost gauge?
Old Sep 28, 2007 | 12:40 PM
TTsumibishi's Avatar
Default Can I use a slightly larger diameter vacuum line for my boost gauge?
Hi everyone,
I have a ProSport performance electrical boost gauge I'm installing shortly. The sender and vacuum tee are both about 3/16". The nylon pressure line they gave me is about 1/4" outside diameter and a little less than 3/16" inside diameter. However, the fit is excruciatingly tight, and it took me hours to get it on the sender. I have some extra 5/16" outside/3/16" inside diameter nylon (clear) hose from another project and the fit is very snugly over the tee and sender er, 'nipple'. (for lack of a better term)
My question is, for only the tee->sender, is using a slightly larger inside diameter line going to be ok? Or will this potentially mess with my readings or boost levels?
Thanks everyone!
- TTsumi
Old Sep 28, 2007 | 01:37 PM
blackfnTTruck's Avatar
No expert, but as long as the connection is tight, I don't think it should matter.
Old Sep 28, 2007 | 02:32 PM
Thanks...we'll find out soon enough, if I decide to stick with the ProSport gauge in the end
Old Sep 28, 2007 | 06:45 PM
DumpTTruck's Avatar
Make sure you use some clamps so it doesn't blow off under boost.
Old Sep 28, 2007 | 06:48 PM
Basttion's Avatar
The pressure will be the same, so yes.
TToddlymatic
Jan 10, 2005 11:00 AM
paul0578
May 7, 2003 04:02 PM
VenomousA4
Feb 20, 2003 01:42 PM
coocoomike
Nov 4, 2002 04:48 AM
