Motor mount bolt stripped. Solution found??
Old Sep 30, 2007 | 05:12 PM
Green TT's Avatar
New Member
Default Motor mount bolt stripped. Solution found??
Aluminum shavings feel out of one of the bolt holes when I took the motor mount out while I was changing the timing belt. It was clear that the threads were stripped out of the mount. I don't remember anything unusual during the previous install (60,000 miles ago).
Of course this happened on Saturday at 7:00 so my options were limited. Couldn't find a 12 mm helicoil and there appears to be some question if this is a suitable application. My solution was to tap it for a 1/2"-20 grade 8 bolt. This fit through the console without modification and the drill size for the tap is very close to 12 mm. I was able to torque the bolt to 85 nm. This is above the 60 nm for the original bolts but less than a full 90 degrees beyond 60 nm. I found 85 nm listed for the original bolt in Bentley in a different set of instructions.
Two questions:
1. Could the threads have sheared off while in use?
2. Anything I should be concerned about with my solution?
Green TT
Old Sep 30, 2007 | 10:37 PM
M power this!'s Avatar
Default If it's played with those threads give way. I just replaced that part. PITA!
the threads seem to give up if the mounts are changed, adjusted, etc.
murphyb
Mar 20, 2013 06:06 PM
kemperflow
Suspension Tuning Discussion
Aug 8, 2007 08:47 PM
eurotrippin'
22
Jun 1, 2007 08:08 PM
tobin
Nov 11, 2006 12:27 PM
mladen
Dec 27, 2002 04:37 PM
