Dr. Schwing; regarding the RTV fix for tCarbon's MAP flange ...
Old Sep 30, 2007 | 05:59 PM
N9909E's Avatar
Junior Member
Default Dr. Schwing; regarding the RTV fix for tCarbon's MAP flange ...
<center><img src="http://pictureposter.audiworld.com/51787/map_test_36.jpg"></center><p>I used Hi-Tem / Hi-strength RTV (about 160psi shear) and tested at bout 34# pull-out. Test successful.
Whaddya think?
Old Sep 30, 2007 | 06:03 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Pretty good!......>>
I'd throw a clamp or a few zp ties over the assembly too to keep potential movement to a minimum! That way, any outward pressure will be taken up by the mechanical support and not stress the RTV..
Old Sep 30, 2007 | 07:00 PM
HACK THS's Avatar
Whats RTV?
Old Sep 30, 2007 | 08:47 PM
HACK THS's Avatar
Default Would either of these products work?
http://www.amazon.com/dp/B00086I6TS/ref=nosim/?tag=becomecom-20&amp;creative=380333&amp;creativeASIN=B00086I6TS &amp;linkCode=asn
http://www.amazon.com/Permatex-COPPER-Hi-Temp-Silicone-Gasket/dp/B0002UEOPA/ref=sr_1_6/105-1908311-6058066?ie=UTF8&amp;s=sporting-goods&amp;qid=1191213678&amp;sr=8-6
Old Oct 1, 2007 | 02:20 AM
stilljester's Avatar
Member
Room Temperature Vulcanization
Old Oct 1, 2007 | 01:09 PM
N9909E's Avatar
Junior Member
Yes on the Permatex; I don't knnow about the copper.
Old Oct 1, 2007 | 04:09 PM
HACK THS's Avatar
Where is that stuff sold so I know? Also what dept in the store- automotive, glues, etc?
back2black
20
Sep 21, 2004 12:40 PM
back2black
May 2, 2004 01:14 PM
DM-S4
Jan 24, 2004 04:50 PM
Bob Dobalina RS
Mar 1, 2003 03:19 PM
