audi dealer burn
Old Oct 1, 2007 | 04:04 AM
abstracTT's Avatar
Default audi dealer burn
there was a rattle coming from the engine. it only rattled in low rpm's and whe nit had warmed up.
i took it to audi and paid them the 130 dollars to check the car out. they come back and tell me its the turbo.
i buy a used turbo, take it to a shop thats affordable, and they proceed to replace the turbo. got the turbo replaced. rattle is still there.
they call me and it turns out that its the tensioner. the timing belt is about to go. the mechanic tells me that hes surprised the car has lasted that long.
so not only did i pay for a turbo replacement, but a timing belt change as well.
it was something that i knew needing to be done soon.
it just sucks that audi in their infinite wisdom diagnosed it wrong.
any chance of them giving me my money back? i plan on going there after work and telling them what i think wether they repay me or not.
Old Oct 1, 2007 | 04:10 AM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Money back?
If they had done the work, maybe. No chance on that now...
Old Oct 1, 2007 | 04:12 AM
abstracTT's Avatar
Default Re: Money back?
i just want my 130 dollars that i paid for them to diagnose it. they odviously didnt even look.
no matter i guess, im still going up there today. maybe throw in a few words such as better business bereau, media..who knows. sounds stupid, but it works sometimes.
Old Oct 1, 2007 | 05:43 AM
Basttion's Avatar
Default My take is, they could have
1) knowingly mislead you, hoping to hit you for the timing belt job after work began on the turbo. In this case, they will not admit fault.
2) they actually thought is was the turbo, and since you had the work done somewhere else, you now have no proof that the turbo was not the problem in the first place--unless you yourself have a first hand working knowledge of turbos and can take the old one in, provide evidence that it was actually in the car and that it was fine before removal--difficult at best to do.
3) the independent shop could have screwed you by not telling you FIRST that your turbo was fine, and the problem was the belt etc, and you need to ask them for part of the money back for your new turbo.
BTW, how much did you pay all total for both jobs?
Old Oct 1, 2007 | 05:50 AM
bubba j's Avatar
AudiWorld Expert
Default The second shop didn't provide an opinion on the problem?
You installed a *used* turbo?
Isn't the labor most of the price?
Old Oct 1, 2007 | 06:06 AM
abstracTT's Avatar
Default i really think that audi
just didnt even look. they raised it up and listened to the sound, and said it was the turbo.
i do have the old turbo.
the shop i took it to. he told me he wasnt sure that it was the turbo, but it did sound like it could be. i had already bought a new turbo. told him to put it in. after test driving it after he still heard the sound, then after looking closely, saw that it was the timing belt.
all said and done it cost 1100 dollars.
but i had more done to it. the new turbo didnt fit so i had a samco inlet pipe put in, and the exhaust manifold had a crack, so i had a used one put in.
i think they did pretty good and for cheap too.
like i said..alot of people recommended them. all they work on is VW's and audi's
Old Oct 1, 2007 | 06:07 AM
abstracTT's Avatar
Default yea, the labor was the price.
its really not the money, its the fact that audi did what they did. they didnt say they tought it might be the turbo...the ysaid it was the turbo..specifically the propellar.
Old Oct 1, 2007 | 06:22 AM
adminisTerTurbo's Avatar
Default don't waste your own valuable time
it's a lost cause. just fix it and enjoy the car. unfortunately no one knew that shaft play can be manually felt by taking off the cold side inlet hose.
 Pouria Savadkouei
 Michael S. Palmer
Old Oct 1, 2007 | 07:03 AM
DynomiteTT's Avatar
i wouldnt being goin back to that dealer ever again, btw like the sig! haha
Old Oct 1, 2007 | 07:16 AM
TT_Nuge's Avatar
Senior Member
Default Even your tech agreed it might be the turbo before he dove in
What do you expect? They scanned it for codes, none would come up in this instance. And then they tried to determine the cause. $130 ain't going to get you much, they aren't going to remove the turbo and check it for play, they will try to determine where the sound is coming from and give you their best guess. This isn't an exact science, otherwise your tech would have determined right away it was the tensioner and not the turbo.
You're overreacting, next time get a second opinion before work starts and maybe it will help, or maybe not. As you said, your tech wasn't even sure but yet you slam the dealership.
