Front License Plate mod w/ pics................>>
Old Oct 2, 2007 | 10:25 AM
Blue TTop's Avatar
Default Front License Plate mod w/ pics................>>
A no-front-plate ticket has increased to $90 with strict enforcement. I wanted a solution that was strong, would hold up to speed, easy to install & remove, and invisible when off.
Front view -
<img src="http://images28.fotki.com/v1032/photos/1/168597/5419087/DSC04972a-vi.jpg">
<img src="http://images27.fotki.com/v1019/photos/1/168597/5419087/DSC05063a-vi.jpg">
Top view -
<img src="http://images27.fotki.com/v1020/photos/1/168597/5419087/DSC05200-vi.jpg">
Side view -
<img src="http://images27.fotki.com/v1023/photos/1/168597/5419087/DSC05055a-vi.jpg">
I fabricated a mounting breacket that fits behind the lower center grill. The two holes are threaded for bolts or studs.
<img src="http://images28.fotki.com/v1026/photos/1/168597/5419087/DSC04946-vi.jpg">
In this picture I have threaded studs installed. They can be covered with black rubber caps when not in use -
<img src="http://images28.fotki.com/v1030/photos/1/168597/5419087/DSC05266-vi.jpg">
Made up a simple license plate bracket from aluminum stock. Angles chosen so Plate will fit contour of the front bumper.
<img src="http://images30.fotki.com/v40/photos/1/168597/5419087/DSC05037-vi.jpg">
Plate bracket mounted using bolts and 20mm spacers. Plate can be adjusted up or down.
<img src="http://images30.fotki.com/v50/photos/1/168597/5419087/DSC04976-vi.jpg">
Two mounting points were used for the bracket inside the bumper -
<img src="http://images29.fotki.com/v334/photos/1/168597/5419087/LicPlateMountingPoints-vi.jpg">
Diagram of internal bracket -
<img src="http://images25.fotki.com/v908/photos/1/168597/5419087/BracketDiagram-vi.jpg">
Takes less than 60-seconds to completely install or remove. It can be mounted with socket head bolts or with threaded studs and nuts.<ul><li><a href="http://public.fotki.com/BlueTTop/mods/license-plate-bracket/">License Plate Bracket Details</a></li></ul>
Old Oct 2, 2007 | 10:38 AM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Nice solution Tony!
Old Oct 2, 2007 | 10:39 AM
coasTTal's Avatar
That must give those laser shooting police a fit.
Old Oct 2, 2007 | 10:45 AM
BluHeaven's Avatar
hey! you inspired me, I ordered the LCR splitter last night
Old Oct 2, 2007 | 10:48 AM
Blue TTop's Avatar
Thanks Steve!
LobsTTer !!'s Avatar
Member
Default ok your next project...
quick on/off hood scoop. :-)
Thanks in advance Tony. Well done write up.
Old Oct 2, 2007 | 10:49 AM
Blue TTop's Avatar
Hey John! Mostly trying to deal with parking-*****. Not much Laser here.
Old Oct 2, 2007 | 10:51 AM
kodeTT's Avatar
Elder Member
Default very nice...i like it.
one of the better solutions out there. reminds me of the one that a company makes for mini coopers...asymmetrical and makes use of the built-in tow hook area on the minis.
 Pouria Savadkouei
 Michael S. Palmer
Old Oct 2, 2007 | 10:52 AM
Blue TTop's Avatar
Great idea! I can see it already.... speed and/or push-button activated. Hmmmmm.
M power this!'s Avatar
Your fabrication abilities are phenominal! a great fix to an ugly problem
