I would like your help with or ideas on why my car is smoking --->>
Old Feb 8, 2008 | 06:21 PM
golfindaily's Avatar
Default I would like your help with or ideas on why my car is smoking --->>
So the car is an 01 w/ 66,000 miles on it. I noticed if I had run the car for 15 mins or untill the engine had warmed up well and then I let the car idle for aprox. 4-5 mins it would start to smoke out of the exhaust. I thought maybe the engine had some carbon build so I used seafoam and put it into the intake mani and some in the gas tank. Well it def blew out a TON of smoke for a few miles but after a few days I ran the car untill it was nice and warm and let the car idle for 5 mins and once again I saw smoke coming out of the exhaust. I would not say its loads of smoke but def noticable. I changed the oil a few days ago and added a bottle of restore but the car is still smoking. If you have any ideas please let me know. Thanks fyi- i have not noticed any smoke at all while driving and if the car does its smoking thing when i let it idle and then rev it the smoke stops for about 30 sec then starts up again. Please help
Old Feb 8, 2008 | 06:25 PM
XCLR8TT's Avatar
Senior Member
What color is the smoke?
Old Feb 8, 2008 | 06:35 PM
like a grayish tint, looks almost like when you run your car in the cold for the 1st few mins
sTTevo's Avatar
Perhaps it just had sex
Old Feb 8, 2008 | 06:39 PM
XCLR8TT's Avatar
Senior Member
Default Probably nothing wrong then... my engine when idling runs a little rich and blows
a small amount of gray-black smoke.
Old Feb 8, 2008 | 07:35 PM
tylor's Avatar
Member
Default keep an eye on your coolant and oil levels
if one of them gets low suddenly, then you'll know...
Old Feb 8, 2008 | 08:34 PM
ArTT Vandelay's Avatar
Default I have the exact same problem...
except i have 148k miles, and the smoke def smells like oil...
but same symptoms, only smokes after idling for a few minutes, goes away after a quick rev and doesn't manifest while driving.
I don't burn any noticeable oil and dont go through coolant. I'm thinking the PCV system maybe?
car runs/feels great otherwise.
frustrating.
Old Feb 8, 2008 | 08:37 PM
sounds like your explaining exactly what my car does
 Pouria Savadkouei
 Michael S. Palmer
Old Feb 8, 2008 | 10:06 PM
tylor's Avatar
Member
Default check for oil around the inlet of the turbo
if it's your pcv and it's causing it to smoke like that there will be some oil there..
Old Feb 8, 2008 | 11:35 PM
1T42T (aka ZZ CETT)'s Avatar
Member
It's probably just trying to be cool.
