Vag-com output tests show fuel gauge needle not accurate...
Well the tach, speedo and temp needs are fine but the fuel gauge needle's range of motion was off and when it should have come to rest at 1/2 it was off to the right, maybe a half hash mark worth (equivalent to an 1/8 tank higher than it should read).
So I'm thinking the Vag-com diagnostic info tells me this is a f'ed up cluster rather than a sender issue... And therefore more Techron ain't gonna help. Do you concur?
The cluster was already replaced once under warranty, but we're way beyond the warranty now. <b>Has anybody found the BBA-Reman service effective in fixing whacky fuel gauges?</b>
~john
Heard mixed results on BBA-Reman on this subject regardless of their claims...
