I need new O2 sensor, but any clue why these codes showed up today? Coil packs?
Old Feb 9, 2008 | 05:38 PM
N9909E's Avatar
Junior Member
Default I need new O2 sensor, but any clue why these codes showed up today? Coil packs?
TIA -
17524 - Oxygen (Lambda) Sensor Heating; B1 S1: Open Circuit
P1116 - 35-10 - - - Intermittent
16514 - Oxygen (Lambda) Sensor B1 S1: Malfunction in Circuit
P0130 - 35-10 - - - Intermittent
17536 - Fuel Trim; Bank 1 (Mult): System too Lean
P1128 - 35-10 - - - Intermittent
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-00 - -
16688 - Cylinder 4: Misfire Detected
P0304 - 35-00 - -
16687 - Cylinder 3: Misfire Detected
P0303 - 35-00 - -
Readiness: 0010 0001
Old Feb 9, 2008 | 05:42 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Lean can cause misfires....Probably related..>>
But not necessarily a CP problem..
Old Feb 9, 2008 | 06:06 PM
N9909E's Avatar
Junior Member
Default It acts like it's loading up, though, and won't rev. Also, smells like rich out the exhaust!?!
I'm confused.
Old Feb 9, 2008 | 06:09 PM
N9909E's Avatar
Junior Member
Default I replaced the t-carbon pressure tube w/the MAP sensor for the umpteenth time today - maybe I broke
a vacuum line - I dunno.
Old Feb 9, 2008 | 07:21 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Rich can cause misfires too! (not to add to the confusion or anything)...:-)
limbertjh
Mar 10, 2010 09:17 AM
AudiS4inCT
Nov 4, 2006 06:30 PM
s4florida
Apr 24, 2005 09:06 AM
