Fuel rail cleaning
Old Feb 9, 2008 | 06:24 PM
lgleason's Avatar
New Member
Default Fuel rail cleaning
On my Grand Prix, every 30,00 miles I hook up a can of 3m or napa fuel injector cleaner to a kit that hooks right into the fuel rail. For this car I take out the fuel pump fuse to turn it off, screw it onto the fuel rail, start the car and run the can through which cleans the injectors, values, carbon etc..
Is this something that is recommended for our TT's or is this likely to damage something within the systme?
Old Feb 9, 2008 | 07:10 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Just put a bottle of Techron in the fuel every few months...>>
No need to go to that extent....
Don't Pontiac's have fuel filters??...LOL..
Old Feb 9, 2008 | 07:11 PM
leveTT's Avatar
Member
Default Why would you do that ...
since it is not recommended by the manufacturer? I would only do it if I diagnosed a problem with the injectors. Most (all?) gasoline has injector cleaners in it.
Old Feb 9, 2008 | 07:21 PM
roadyTT's Avatar
Default An excellent observation...
Most name brand gasolines aren't name brand until a compliment of additives are introduced prior to selling. Techron gas stations for example have a Techron additive.
Old Feb 9, 2008 | 08:08 PM
Tom1222's Avatar
Member
Default Use Seafoam. Here is what you do.....
First buy a can of Seafoam at your local Autozone, Advance Auto or Pep Boys.
Take off the Vacuum hose from the Fuel Pressure regulator. Pour about 1/2 - 2/3 of the can of Seafoam into a shallow container. Start your car and let it idle. Carefully take the Vacuum hose and slowly let it suck in the Seafoam solution. Do this slowly. A little at a time so the car wont stall. You will notice large amounts of white smoke pouring out of the tailpipes which is quite normal. After it sucked in all the fluid shut off the engine and let it sit for about 10-15 minutes. Reconnect your FPR hose and start your car. Take it for a little drive for about 10-15 minutes. It will contiune to smoke for a little while. This treatment will effectively clean your Intake, valves and cylinders. Pour the rest into your Gas tank to clean the injectors.
I just done a Seafoam treatment today and the car runs great and the idle seems to be smoother. Prior to an oil change you can also pour up to half a bottle into the crankcase to clean the engine and disolve sludge. I wouldn't drive more than maybe 100 miles before changing your oil since Seafoam will thin out your oil a bit. Seafoam really is great stuff and will clean your engine better than most of the other so called miracle fluids on the market.
Old Feb 9, 2008 | 08:57 PM
golfindaily's Avatar
actually on the bottle it explains all of those procedures, great stuff, b5 s4 forum loves it!
Old Feb 10, 2008 | 03:41 AM
roadyTT's Avatar
Yep...and have a spare set of plugs ready "just in case"
Old Feb 10, 2008 | 04:53 AM
IndyTTom's Avatar
New Member
Why a spare set of plugs? Will Seafoam make the old ones explode? :-)
 Pouria Savadkouei
 Michael S. Palmer
Old Feb 10, 2008 | 04:54 AM
MCPaudiTT - DEFCON 1's Avatar
Tech Guru
What does this do to the cats?
Old Feb 10, 2008 | 05:04 AM
TTinCT's Avatar
Rest In Peace
Default lol....no...it is possible they could foul, which is not>>>
a common issue on fuel injected cars...
