Sorry for all the questions but new car with concerns and heres another ->
Only with cold engine would lead bact to the temp sensor we talked about. If I were you I would get a green one and put it in. Mine finally caused an error code before I changed it, but it caused funny idle and some engine going dead before that happened.
Good Luck!
This can be caused by...
1- dirty fuel filter
2- not enough gas in the tank to fully pressurize the fuel rail
3- potentially an early sign of a fuel pump issue...(although this is less likely)
Also note that number 2 on this list is more than likely what most experience here. As msuave noted, wait for the OK light to come on in the dash, then start.
