Do you need to remove bumper to install a grille??
there was a good write up on this a while back.. give the way back machean a try
BUMPER REMOVAL
1) Jack up, remove front wheels
2) Remove front part of fender liners
3) Remove the 2 10mm nuts on studs at the corners toward the sides holding the nose to the body shell. Loosen 2 torx bolts holding black side clip
4) Remove the 6 torx bolts along the top of the nose
5) Remove 2 phillips screws at the bottom
6) Pull nose off, unclip aliens.
