front sway bar with downpipe install??
Old Feb 11, 2008 | 09:29 AM
oldschooleuro's Avatar
New Member
Default front sway bar with downpipe install??
I'm getting my 42 DP installed on tuesday of next week and I've been having a clunk in the front end whenever I start or stop moving in traffic and what not. That being said I've changed the bushings in the control arms (wish I had put defcons in at the same time) and the dogbone mount trying to get rid of the clunk. A while ago I had my car at the dealer and they mentioned that the front sway bar needed to be replaced, which I ignored as they wanted to charge me 500 for the job. Am I correct to think that the subframe has to be dropped to put in the DP? If so, is it a good idea to buy a front sway bar now to save on labor?
I was going to try to do all the work myself but after hearing what a PITA the downpipe is, I figured I'd pay someone to suffer with it for a couple hours
Old Feb 11, 2008 | 09:54 AM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Might as well do it at the same time....(yes on dropping the subframe)
Old Feb 11, 2008 | 12:01 PM
DynomiteTT's Avatar
Default u really think so? i have one that i might install but
i was told labor would be outrageous for both..
Old Feb 11, 2008 | 12:58 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Because it's a PITA and requires an alignment after....>>
If you don't know the trick...:-)
Old Feb 11, 2008 | 04:46 PM
DynomiteTT's Avatar
Whats this trick you speak of?
Old Feb 11, 2008 | 04:50 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default You can avoid the alignment if...>>>
You take a Camber index reading on both sides before dropping the subframe. When re-bolting, nudge it back to the same readings and you'll retain your previous alignment settings.. I doubt many shops do this though..
<img src="http://images30.fotki.com/v479/photos/7/7305/1232358/DSC02586-vi.jpg">
Old Feb 11, 2008 | 08:07 PM
sTTevo's Avatar
Default No need to replace sway bar. Just get poly bushings and break off OEM plastic sleeve.
Not very difficult to do yourself. Replace old rubber bushings with 20mm polyurethane.<ul><li><a href="http://www.ttstuff.com/performance_suspension_bushings.php">number 3 in theTTStuff figure</a></li></ul>
Chapaarell80
Audi Original "S" Cars
Apr 19, 2008 11:35 PM
s4wood
Oct 25, 2004 06:38 PM
bianchi
Oct 15, 2004 06:51 AM
StormChaser404
Dec 20, 2002 11:28 AM
bryantchoung
Audi allroad
19
Nov 16, 2002 08:32 AM
