Overheating when at Idle - Yep Something Wrong....
Old Feb 12, 2008 | 03:10 PM
coasTTal's Avatar
Default Overheating when at Idle - Yep Something Wrong....
This first started the other day after a very heavy and icy dump of snow that the plows just left in the middle of the road. My belly pan got deposited somewhere and snow got packed between the engine and fan. Apparently the snow kept the fans from turning when called for and screwed something up.
Not being real knowledgeable of how the fan system works and how it is hooked up I am not sure what to go looking for.
I have driven the car several times since this happened and the temp. stay right where it should be. Mind you it has not been above freezing in sometime here in Chicago. Today, I had to wait for my wife and as the car idled the temp. shot up to the 3/4's mark. I revved the engine, made sure the A/C was supposed to be on (doubt it would work at this outside temp.) and still the water temp. would not come back down. Only after driving and pushing air through the radiator did the temp. come back to normal.
Apparently I have a problem and do not know much about the fan system.
As you face the engine the right most fan can turn, but not spin freely when pushed with my hand.
What are your thoughts on how this works and what would be the problem solving for the issue?
Thanks, John
Old Feb 12, 2008 | 03:15 PM
choptt's Avatar
Default new fans
new fans. check the fues too, but if the fans are hard to turn or won't turn at all,then they need to be replaced. call germancarparts.com, they might have them for cheap.
Old Feb 12, 2008 | 04:00 PM
SunSeTT - Lab RaTT's Avatar
Default Had this issue quite a bit... one thing to try here...
is to check the fans to see if they are turning. If not, go to your battery. ON TOP of the battery there is a fuse holder. In that fuse holder there are several green fuses... wiggle I believe it's the middle one back and fourth while the car is on.... Usually when this fuse is bad, your AC blows hot too though..
If not it can be the fan control module, or as the other gent said... bad fan - OR Temp control sensor
Old Feb 12, 2008 | 06:28 PM
nightdweller's Avatar
New Member
Default I had problem last winter
turned out to be a water pump that had decided to break into pieces.
Nathan
mmasner
Audi allroad
Jul 5, 2015 05:19 AM
jtazz1966
Dec 7, 2007 10:22 PM
forced induxion
Jul 3, 2006 01:03 PM
Gingerbread man
Canadian Discussion
Oct 24, 2004 08:00 PM
TabulaRasa
Mar 18, 2003 05:07 AM
