Strange humming noise (now with Video)
Old Feb 13, 2008 | 09:24 PM
mosmoe (OPG)'s Avatar
Default Strange humming noise (now with Video)
I have a 2001 stage 2 TT (see mod list below). I have been hearing a strange humming noise coming from (what seems to be) the front of the car on the left side. It doesn't matter how fast I am going or what rpm I am at. It happens between 3inHg and 0psi.
Any ideas?<ul><li><a href="http://video%20of%20noise">http://video.google.com/videoplay?docid=-7856077288375625686</a></li></ul>
Old Feb 13, 2008 | 09:36 PM
kTTang's Avatar
Default Fixed link
<ul><li><a href="http://video.google.com/videoplay?docid=-7856077288375625686">http://video.google.com/videoplay?docid=-7856077288375625686</a</li></ul>
Old Feb 13, 2008 | 09:41 PM
JohnLZ7W's Avatar
Default Sounds like my car...
Have you recently done any work to vacuum lines, maybe replaced the PCV valve?<ul><li><a href="http://boozebags.com/jwiegert/uploads/picpost/MVI_2671.AVI">right-click, save-as</a></li></ul>
Old Feb 14, 2008 | 03:25 AM
TTinCT's Avatar
Rest In Peace
Default interesting........yours almost sounds like >>>
the turbo itself.....Like it is winding down from a spool....
Old Feb 14, 2008 | 03:27 AM
TTinCT's Avatar
Rest In Peace
Default definitely helps.....>>>>
based on the description....what type of vaccuum line did you use rubber or nylon? It is possible that there is a harmonic thing going on between the gauge and the FPR....
Old Feb 14, 2008 | 04:29 AM
iMMix's Avatar
I have exactly the same sound in my car too... any ideas/solution?
Old Feb 14, 2008 | 04:39 AM
Basttion's Avatar
sounds like a whale!
Old Feb 14, 2008 | 04:54 AM
GeTT da NeTT's Avatar
Boy, that sure sounds like a vacuum problem. R&amp;R your PCV valve and see if it persists
 Pouria Savadkouei
 Michael S. Palmer
Old Feb 14, 2008 | 05:59 AM
JettaTT Love Child's Avatar
Member
Default My car makes a similar sound around 3100 RPM but nowhere else in the RPM range. I attribute it to
my wak TT swiss cheese air box making a whistle noise. Most of the time it doesn't even happen but if i get it right at the correct RPM then the airbox seems to whistle a bit. It only started happening after i cut up the bottom of my air box a bit, so I think it is that. Where does the sound seem to come from?
Old Feb 14, 2008 | 06:04 AM
TTinCT's Avatar
Rest In Peace
yours could possibly be the DV at that RPM....
