Car question....not Audi related.....for you expert mechanics out there
Old Feb 14, 2008 | 03:04 PM
Kareem of Elise's Avatar
Default Car question....not Audi related.....for you expert mechanics out there
So, my beater daily driver if you remember is a '95 Ford Escort (160k miles), FWD, 5 speed.
I notice this on the highway, mostly....when accelerating, the car pulls to the left, then, when I let off the gas (not touching the brakes), it pulls to the right. If I'm maintaining constant speed, it's neutral, it's just the on throttle/off throttle.
Old Feb 14, 2008 | 03:16 PM
GeTT da NeTT's Avatar
motor mount/transmission mount. What do I win?
Old Feb 14, 2008 | 03:18 PM
N9909E's Avatar
Junior Member
Default Most likely unequal length axles. More torque (+ and -) on one side.
= torque steer.
Old Feb 14, 2008 | 03:24 PM
Default I'm familiar with torque steer, but....
this only started recently. Plus, a '95 Escort probably has negative torque.... :-)
Old Feb 14, 2008 | 03:25 PM
Think so, huh? Ok, when it warms up a bit, I'll check.
Old Feb 14, 2008 | 03:26 PM
..and your prize is I'll send you the broken one.
Old Feb 14, 2008 | 03:30 PM
Default Paul, they may be broken our just worn out. Your symptoms are consistent
with all three mounts having dropped. Swap them out and I think you'll feel pretty good about your beater.
Old Feb 14, 2008 | 03:31 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default If recent then...>
Probably some worn suspension bushings....Doh! at that mileage fer sure..
Motormounts suspect too...
 Pouria Savadkouei
 Michael S. Palmer
Old Feb 14, 2008 | 03:33 PM
Possible. I actually know this car from past experience. MMs are a good bet here
Default OK, cool....I'll order some new ones.......
I guess it doesn't surprise me at 160k.....BUT...still the original clutch, believe it or not!
