ok, I give up and I'm bummed - try as I might >
Once you pull that the connector will just unplug..
Look for another similar plug for a clue as to how that one releases..
The connection at each injector has a wire clip to hold it in place. Here is a picture of the underside -
<img src="http://images35.fotki.com/v1129/photos/1/168597/3093854/DSC02667-vi.jpg">
Thanks though, on the connector info - I'll go study the headlights and see what I can do.
The "junior timer" type, commonly used on fuel injectors. These have a metal bail going most of the way around the connector, and just pull off.
<img src="http://www.flatsurface.com/pics/vw_jr_timer.jpg">
The "two metal ears" type. These have a wire running around the connector, the ends of which are bent up to form two "ears." You squeeze the ears together to release it.
<img src="http://www.flatsurface.com/pics/vw_2_ears.jpg">
The plastic tab type. These are the trickiest. In my experience, grit/oil can get into the shell and make removal difficult. The tab pushes toward the connector body to release. I've had the best luck with these by first pushing the connector together firmly, them pushing the tab, then pulling apart.
<img src="http://www.flatsurface.com/pics/vw_plastic_tab.jpg">
