Throttle body code
Old Feb 15, 2008 | 02:10 PM
RemixTT's Avatar
Default Throttle body code
I just got chipped and the vag threw a throttle body fault. They said it was sticking and they said they tapped it but was still sticking. What causes this and what can I do to fix it other than getting a new throttle body?
....BTW I love the chip! That should've been my first mod, before the exhaust, intake, brakes, audio system, and suspension!
Thanks in advance!
Old Feb 15, 2008 | 02:52 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Clean it....>
Take it off an use some Throttle body cleaner or Brake clean...There is a residule build-up that can cause the butterfly to stick..<ul><li><a href="http://public.fotki.com/RoberTT/maintenance/throttle_body_cleaning/">RoberTT's pictures and write-up here..</a></li></ul>
Old Feb 16, 2008 | 08:48 AM
Walmer's Avatar
Default Will the battery disconnect work to get the car to adjust the Throttle Body instead of the VAG?
I have encountered a stumling or searching idle in the past. I have used the battery disconnect and then let the car go through it's TB allignment on it's own. Just wondering if the VAG is required or if this should work?
Old Feb 16, 2008 | 09:01 AM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Yes......Just....>
Turn the key on (no start), door open, don't touch the throtttle pedal and it will self adjust in about 15 seconds (you can hear it)
S4incter
Oct 26, 2008 05:03 PM
golovokruzenia
Apr 9, 2004 05:01 PM
S4_downunder
Jun 5, 2002 09:57 PM
S4_downunder
Jun 5, 2002 07:57 PM
Sourdough Josh
Mar 7, 2002 11:06 AM
