Ugh - the deed is done - Dahlback installed >
<img src="http://pictureposter.audiworld.com/53277/dahlback_install_001.jpg">
Fuel rail and injectors out of the way; interestingly, BOTH nuts securing the manifold were loose, and ALL BUT TWO of the cap screws holding it on were barely finger tight - arrrgh.
<img src="http://pictureposter.audiworld.com/53277/dahlback_install_003.jpg">
Yes, these ports could clearly use port-matching.
<img src="http://pictureposter.audiworld.com/53277/dahlback_install_017.jpg">
Almost done - everything's installed and the engine fired up. Worth noting, reinstalling the injectors was a real pain - the fuel rail DID NOT re-seat properly - flush and tight - on the casting bungs designed for it; I'll need to go back in and install some spacers.
<img src="http://pictureposter.audiworld.com/53277/dahlback_install_025.jpg">
I decided to go back in and clean up the hoses - here's a "before" pic for reference:
<img src="http://pictureposter.audiworld.com/53277/coolant_misc_007.jpg">
Moved the fuel pressure gauge and replaced a bunch of hoses with silicone; anyway, done for the time being - still need to go in and install my SFS DV Relo hose in lieu of the Forge kit on there now.
<img src="http://pictureposter.audiworld.com/53277/dahlback_install_026.jpg">
