The fuel pressure regulator adjustment begins...
I am trying to take a baseline before I start adjusting fuel pressure. I logged blocks 031 and 032 (graph above is of 32) over block 002. Can anyone help me interpret the graph above?
Get the correction as close to "0" as you can, erring on the rich side (so less Fuel pressure in this case). Keep the A/F in the 12:1 range for max power..
<img src="http://images29.fotki.com/v290/photos/7/7305/776256/fueltrim-vi.jpg">
<img src="http://images107.fotki.com/v542/photos/7/7305/130918/MAF_af-vi.jpg">
On the onset, Zero it out (turn fully COUNTERCLOCKWISE), then start turning clockwise until you just start to feel it snug up a little. This is usually at 1.5-1.75 turns, On the regulator, determine how many turns you are at by turning CLOCKWISE to the stops, re-set to where it was and add another turn counterclockwise....Continue advancing the regulator until you get a nice 22psi peak in a high torque 3rd gear throttle application..
Always measure in 3rd gear.
A good suite of diagnostic blocs are:
002 (Mass air)
118 (intake temp, N75 duty, IC pressure)
204 (Command, IC, and Manifold pressures)
3rd gear start at 2K, then go WOT to redline..
