parts coming in today! going to tackle SAI pump fix, what hardware should i pickup prior to work?
Old Feb 19, 2008 | 02:11 AM
VorsprungTT's Avatar
Default parts coming in today! going to tackle SAI pump fix, what hardware should i pickup prior to work?
Also anyone ever do their own tints!? Yea I've got to be stupid to try this one. Well question is how do I disable the auto window up/down feature when doors are opened then closed?
Thanks guys... New OEM MAF should be in with an oil change, tints, SAI pump fix, new strut mounts, check for VAC leaks because something is wrong with this SOB. I'm going to check for a cracked boost gauge line too because that thing is fickle as hell (needle vibrates). Also through all the madness I might lay a coat or two of paint down on my one silver wheel(due to brake fluid
After all this fun-ness if the shop is still open I'm getting my spring alignment! WOO FINALY!
See you all in the morning. As if it's still night at 6am.
Old Feb 19, 2008 | 04:57 AM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default To disable...>
The window drop down just fli the latch in the door jam with a screwdriver...Don't forget to reset it before you slam a door!
Old Feb 19, 2008 | 09:20 AM
Thanks steve. What about the next few days? that 1cm movement effect the tint?
Old Feb 19, 2008 | 09:25 AM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Wasn't a problem on my car......and..>>
from what I read it's really not an issue in general...
Old Feb 19, 2008 | 09:32 AM
Scenic Driver's Avatar
You can also pull fuse 14 (interior lights) to disable the windows
Rangeroverdude
Audi A3 / S3 / RS 3
Jul 19, 2018 04:31 PM
CarlsAudi
Audi 100 / A6 (C4 Platform)
11
May 2, 2014 09:57 AM
GDawgA4
Jun 8, 2008 05:34 AM
idriveab5A418T
Jun 1, 2006 04:13 AM
TPW
May 9, 2005 06:38 AM
