Rear brakes time. Anyone used this type tool for rotating the piston?
Old Feb 21, 2008 | 05:23 PM
N9909E's Avatar
Junior Member
Default Rear brakes time. Anyone used this type tool for rotating the piston?
<center><img src="http://pictureposter.audiworld.com/51787/brake_piston_rotating_tool.jpg"></center><p>Thanks.
Old Feb 21, 2008 | 05:26 PM
MarTT's Avatar
I tried that once. Works but not that great. Get the real deal - free rental from Autozone.
Old Feb 21, 2008 | 06:01 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default I'll let you know...>>
next week. I've done the channel-lock trick which works fine but this should be easier. Picked up one of these to do the Mini (similar Brakes)...Cheap enough to have around..
Old Feb 21, 2008 | 06:08 PM
J. Patterson's Avatar
I bought one but none of the sides worked on the TT rear piston. Want mine ? :-)
Old Feb 21, 2008 | 06:35 PM
JohnLZ7W's Avatar
Default Yep, used one just like that last weekend, worked fine
<center><img src="http://hock.net/images/bmw/compressing-caliper-piston.jpg"></center><p>Took off just the top caliper bracket bolt and let the caliper pivot on the bottom bolt. Pulled it away from the rotor and used this exact style clamp along with the cube you posted. Used a screwdriver to turn the cube while increasing pressure on the clamp.
Old Feb 21, 2008 | 07:10 PM
carsluTT's Avatar
wow that looks/sounds unfun, kind of like using a "self teeth cleaning kit".....
Old Feb 21, 2008 | 07:14 PM
N9909E's Avatar
Junior Member
Isn't that called, like, a "toothbrush"?
Old Feb 21, 2008 | 07:19 PM
JohnLZ7W's Avatar
Default Took like 10 minutes per side, really not that bad.
I do need to invest in the real tool tho, just because The Stoptech pistons I was able to push in just by pressing against them with my fingers.
 Pouria Savadkouei
 Michael S. Palmer
Old Feb 21, 2008 | 07:24 PM
MaxAudi67's Avatar
Default I used this one last weekend. It works great and is very
cheap. $26 or so. Has an adapter that fits great. Also works on the front.<ul><li><a href="http://www.audipages.com/Tech_Articles/susp_whls_brake_steer/rearbrakes.html">http://www.audipages.com/Tech_Articles/susp_whls_brake_steer/rearbrakes.html</a</li></ul>
Old Feb 21, 2008 | 07:25 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Here in the South they use Jerky.....:-)
