It's a bit noisier... (first VF impressions & some install notes) >
The driver's side actually required lowering the engine a few inches to get the old mount out, but otherwise relatively straightforward; torquing not really a problem. Battery and air intake needed to be pulled, but otherwise a fast effort.
<img src="http://pictureposter.audiworld.com/53277/2_23_08_011.jpg">
The passenger's side was a little bit more of a pain - more on that later, but generally pretty fast too. Had to pull the coolant reservoir but other hoses did not require disconnecting, and the mount did come out without any significant maneuvering of the engine.
<img src="http://pictureposter.audiworld.com/53277/2_23_08_017.jpg">
Yup, there it is, peeking out below the PS reservoir!
<img src="http://pictureposter.audiworld.com/53277/2_23_08_022.jpg">
And another, 'just to prove it's in there'. ;-)
<img src="http://pictureposter.audiworld.com/53277/2_23_08_025.jpg">
This one's really easy, not much else to say about it.
<img src="http://pictureposter.audiworld.com/53277/2_23_08_031.jpg">
Here's where I might have done some unintentional damage - in the maneuvering of the mount under the hoses, it seems like the fittings on this reservoir came loose. There are actually 4 lines total into it, just on the passenger compartment side of the coolant tank - you can barely see the bottom one, with the Audi rings on it - that one that I seemed to be able to push back into place and it seems secure. I'm not sure offhand what's actually going on here, and/or if they can be just push-locked back into place or if I need to replace the entire component
<img src="http://pictureposter.audiworld.com/53277/2_23_08_033.jpg">
Slightly more close-in:
<img src="http://pictureposter.audiworld.com/53277/2_23_08_036.jpg">
And closer still - the line with the yellow mark on the clamp is the only one I can't seem to re-seat; anyone know anything about these/this? I risk getting debris into the system like it is.
<img src="http://pictureposter.audiworld.com/53277/2_23_08_042.jpg">
Anyway, done...
