Rear Brake Piston Stuck?
Old Feb 24, 2008 | 11:21 AM
bullitz400's Avatar
New Member
Default Rear Brake Piston Stuck?
HEy guys. Followed Schwings write up on rear brakes. Took the pads out, saw even wear and came to conclusion pistons wern't stuck. take them out, twist the piston with big pliers. take the c-clamp to compress and won't budge. Fronts moved real easy. Parking brake is off, cable is off, can't figure out why? Any suggestions? Thanks
Old Feb 24, 2008 | 12:04 PM
msauve's Avatar
Default You have to twist and push at the same time...
<center><img src="http://www.harborfreight.com/cpi/photos/40700-40799/40732.gif"></center><p>one of these makes it easy.
Old Feb 24, 2008 | 12:19 PM
mad scientist's Avatar
Junior Member
Default you can usually rent one at FLAPS
friendly local auto parts store.
Old Feb 24, 2008 | 12:26 PM
bullitz400's Avatar
New Member
Default Re: you can usually rent one at FLAPS
Trying Autozone!! Is there a certain name for the piece?
Old Feb 24, 2008 | 12:37 PM
XCLR8TT's Avatar
Senior Member
Brake Caliper Piston Tool
Old Feb 24, 2008 | 03:07 PM
bullitz400's Avatar
New Member
Default Re: Brake Caliper Piston Tool
Awesome got it, works, brought back. Hardest part was getting the little clips to go in securely lol. Thanks again!!
Old Feb 25, 2008 | 08:50 AM
bullitz400's Avatar
New Member
Default Parking Brake Cable??
Hey guys. Got one side completly done that I didn't have to dick aroudn with at all. At the beginning I got frusturated so i went to the manual and took the parking brake cable off for w/e reason and its a p.i.t.a. to get back on. Any helpful hints to get it back into place? THanks
jcanon
Q5/SQ5 MKI (8R) Discussion
Feb 22, 2015 10:19 PM
cssaudi1
Brakes Discussion
Dec 8, 2013 08:15 AM
uffo
Nov 24, 2002 07:07 AM
DocWyte
Feb 26, 2001 06:23 AM
Jad
Jul 30, 2000 08:42 PM
