Ok dam you guys, the sway bars are back on. Will rear rotors fit in the front?
Old Apr 1, 2008 | 07:39 PM
esanmiguel's Avatar
Default Ok dam you guys, the sway bars are back on. Will rear rotors fit in the front?
I thought the sway bars didnt really matter much for handling unless they were upgraded to like 19mm aftermarkets, but oh well.. You guys convinced me. Now instead of saving weight on the sway bars, i noticed the front rotors are MUCH heavier than the rears.. Can I just get rear rotors installed on the front? Maybe get them slotted or cross-drilled to compensate for the smaller diameter? What do you guys think?
Old Apr 1, 2008 | 07:44 PM
DumpTTruck's Avatar
You're funny.....
Old Apr 1, 2008 | 07:45 PM
carsluTT's Avatar
Default 4real?....... dude if ur that worried bout weight go buy a 1984 GTI!....
there super light and super fun and super cheap!..... i own and have built a lot of them 4 others, im puting a 01 225 1.8tinto one right now even.......
Old Apr 1, 2008 | 07:52 PM
GorTT's Avatar
get lighter brakes - calipers and rotors; many out there.
blueprinTT's Avatar
Member
Default Don't stop there....cross-drill your ECU.....
...the TT only uses 10% of it's brain anyway.
April fools! ;-)
Old Apr 1, 2008 | 07:54 PM
|everso!|'s Avatar
you don't really need rotors in the front....set those wheels FREE!
Old Apr 1, 2008 | 07:58 PM
XCLR8TT's Avatar
Senior Member
Default Cross drilled brake lines FTW
<ul><li><a href="http://kalecoauto.com/index.php?main_page=product_info&amp;cPath=1&amp;p roducts_id=1">http://kalecoauto.com/index.php?main_page=product_info&amp;cPath=1&amp;p roducts_id=1</a</li></ul>
Basttion's Avatar
Go ahead, you still have three more minutes of april fools left.
 Pouria Savadkouei
 Michael S. Palmer
Old Apr 1, 2008 | 08:01 PM
GorTT's Avatar
actually, if you took off the door, he could just stick his foot out...
Old Apr 2, 2008 | 03:04 AM
PracTTical's Avatar
ok you're definitely mocking us aren't you....
