Serp belt size to use if removing A/C compressor
Old Apr 2, 2008 | 07:10 AM
OldSchool AG's Avatar
Senior Member
Default Serp belt size to use if removing A/C compressor
couldn't find any posts on this topic in the archives.
Has anyone ditched A/C, and if so, what length serp belt did you use? Otherwise I guess I'll be doing some measuring.
Or, if A/C delete was a European option, would someone over there be so kind as to check the spec in your owner's manual?
Old Apr 2, 2008 | 07:11 AM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Finally a good weight delete plan!...>>
Lemme check my Euro spec Etka..
Old Apr 2, 2008 | 07:18 AM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default No Luv Chris.....>>
Checked early Chinese and Mexican market cars...Looks like there was no AC delete..
Senior Member
Default thanks
also, anything that is held on by more than one fastener, I'm removing the extras. small, but they add up fast!
Old Apr 2, 2008 | 07:19 AM
Senior Member
Default oh well. wouldn't be the first time i bought 3 diff sizes and returned 2
when doing something like this
just need to measure "close" and fine tune with real belts
thanks for looking!
Old Apr 2, 2008 | 08:30 AM
TTempted's Avatar
Guest
Default you could...
probably get away with only one windshield arm too
I also see in your picture that your cellphone antenna is still on as are your badges in the front. Jeesh, with all of that weight, I'd suppose you have your lower grills still installed in the front too!
Old Apr 2, 2008 | 09:05 AM
GorTT's Avatar
The euro quattrosport had no AC - maybe email TT Shop for a PN, or just search VW 1.8's?
Old Apr 2, 2008 | 09:13 AM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Winna!!! Here's the part number and dimensions....(Ooops...3.2)>>
BUT, That's the 3.2 so none of this is probably any good....
06A 145 933D
Dimensions: 21,18 x 1120mm (AC model is 1195mm)
 Pouria Savadkouei
 Michael S. Palmer
Old Apr 2, 2008 | 09:26 AM
GorTT's Avatar
:-) I was happy :-( I was sad !
Old Apr 2, 2008 | 09:43 AM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default At least your brain was working at 50-%.......>>
Which is more than most!
