Getting ready for QDM need more advise on fluids and suspension
Old Apr 2, 2008 | 07:53 AM
nightdweller's Avatar
New Member
Default Getting ready for QDM need more advise on fluids and suspension
I want to change the Trans fluid and fluid in the diff's also finally putting on the Wilwood BBK that has been sitting in the garage. What fluids should I order for these things?
finally getting the Bilsteins and Eibach on as well. Other than new strut mounting bit's what else should I order ball joints, bushings etc. I figure I might as well replace things while i'm in there.
Thanks, Nathan
Old Apr 2, 2008 | 08:13 AM
LiTTespeed's Avatar
take out your sway bars!
Old Apr 2, 2008 | 08:18 AM
roadyTT's Avatar
LOL!
Old Apr 2, 2008 | 08:40 AM
Lowcountry's Avatar
Default Go ahead and do the defcons while you're in there.
You'll be glad you did and you'll save some $$ on install.
Old Apr 2, 2008 | 08:43 AM
RoberTT-WWCD's Avatar
Default For the quattro tranny...>>
Get 3 quarts of Redline MT-90 (ECS has a kit) If you DYI, you will need a 17mm allen socket (ECS has this as well). You will also need something to pump the fluid back into the tranny.
On the brake fluid, I use ATE Super Blue.
On suspension, If a high mileage car, I would get sway bar down links all around. Makes a world of difference.
Old Apr 2, 2008 | 08:54 AM
New Member
Rather than do that an efffects that that can cause. I'm just running 3 lugs per wheel
Old Apr 2, 2008 | 08:56 AM
New Member
Thanks. Mileage is right at 70K. What about the diff's?
Old Apr 2, 2008 | 08:58 AM
New Member
Default i'd love to but that'll be down the road. With the work schedule I'll be
lucky to get the other things done.
Nathan
 Pouria Savadkouei
 Michael S. Palmer
Old Apr 2, 2008 | 09:13 AM
Default I haven't change that yet but it's a good idea. You can use MTT090 as well...>>
I'm not sure how much though.
Old Apr 2, 2008 | 09:15 AM
New Member
Thanks
