To make the radio removal tools from the file folder things is a dremel neccessary?
Old Apr 2, 2008 | 11:44 AM
1 Mean TT's Avatar
Default To make the radio removal tools from the file folder things is a dremel neccessary?
Or would a set of wire cutters/dykes work?
Old Apr 2, 2008 | 11:56 AM
GeTT da NeTT's Avatar
Default Don't need to do anything, just use them. Use the indentations to grab the locking tabs and push
them in.
They are typically a little fat, so you may need to work the head unit up a little...
Good luck.
adminisTerTurbo's Avatar
Default wire cutters will probably work. sheetmetal scissors would probably be even better
use concrete to file down the edges so they don't scratch anything.
Old Apr 2, 2008 | 12:22 PM
dougie's Avatar
25 Year Member
Default buy these
<ul><li><a href="http://cgi.ebay.com/ebaymotors/Audi-Mercedes-Vw-Porsche-Radio-Stereo-Removal-Tool-Keys_W0QQcmdZViewItemQQcategoryZ35625QQihZ014QQite mZ330224643783">cheap!</a></li></ul>
Old Apr 2, 2008 | 12:57 PM
kodeTT's Avatar
Elder Member
Default that metal is fairly soft...and bent under pressure while pulling the radio out.
i sprung for a real set with finger rings on the end. works so much better and assures for a clean removal.
Old Apr 2, 2008 | 03:25 PM
MoneyShifTT's Avatar
Member
Default get the $4 ones from Wal-Mart!!!!>>
I has them! Work flawlessly.
Old Apr 2, 2008 | 06:26 PM
1 Mean TT's Avatar
for which car were they for....i know walmart doesn't have audi
Old Apr 2, 2008 | 08:11 PM
ninjamonkey's Avatar
Default file folder things are okay for a couple uses
It's crude, but it works in a pinch. (Like in the middle of the night, when nothing is open, but you have the urge to tinker.)
Just make sure you have a good notch at the base of the "blade" -- the notch is what catches on the latches inside and give you the ability to pull the radio with the keys. My radio was in fairly tight, so I had to use pliers on the file folder thingys to get enough grip while pulling. The blade part of the key should be nice and long, less than 30 degrees, maybe 3/4" long for it to slide well. Don't worry, there's a lot of room to shove them in.
If you're going to be pulling more than a couple times, buying a cheap tool is probably best.
 Pouria Savadkouei
 Michael S. Palmer
Old Apr 2, 2008 | 08:42 PM
1 Mean TT's Avatar
I stand corrected.....walmart had just the thing
epeephile
New England Discussion
10
Jun 11, 2008 09:18 AM
hurdlrstud
Rocky Mountain Discussion
Feb 27, 2007 05:02 PM
Der Kimbo
Florida Discussion
Feb 16, 2006 07:26 AM
andye12345
Jul 11, 2005 04:08 PM
brrman
Jul 10, 2003 12:21 PM
