odd axle nut size...
Old Apr 2, 2008 | 04:46 PM
ArTT Vandelay's Avatar
Default odd axle nut size...
i would have sworn the front axle nut was 30mm. nope. so i bought a 33mm. too big, spins and rounds the corners. is it a 32?
Old Apr 2, 2008 | 04:50 PM
msauve's Avatar
12 pt, 30mm
Old Apr 2, 2008 | 05:01 PM
Default and yet, not.
the socket is too small. i have the replacement nut, and it will in no way fit in a 30mm socket. it's a little loose in a 33. it's straight from the dealer. i'm stumped. does it HAVE to be a 12pt socket? i'm trying a standard 6pt now...
Old Apr 2, 2008 | 05:10 PM
msauve's Avatar
Default From the days of the Rabbit...
it's been 30 mm, 12 point.
I just went out and checked. Mine fits perfectly. Maybe you got a "cheap Chinese crap" socket, and it's not really 30 mm. Measure both nut and socket with a caliper.
It's an M20 thread, which by DIN standards has a 30mm drive.
Old Apr 2, 2008 | 05:39 PM
rumburak's Avatar
Default ISATI
<ul><li><a href="https://forums.audiworld.com/tt/msgs/1747393.phtml">https://forums.audiworld.com/tt/msgs/1747393.phtml</a</li></ul>
Old Apr 2, 2008 | 06:15 PM
obviously, i'm a tard. it has to be 12pt. thanks all
Old Apr 3, 2008 | 03:49 AM
KenRK's Avatar
Default Keep in mind, those nuts are a one time use item
Get a fresh one each time you tighten it. Believe me, I know, couple of track days cut short for just that reason... :-(
Old Apr 3, 2008 | 12:56 PM
OldSchool AG's Avatar
Senior Member
Default YES, it HAS to be 12 point....
are you saying you're using a 6 point? That definitely won't work. Look at the shape of the nut. Like my 20 month old trying to fit a round peg into a square hole. ;-)
 Pouria Savadkouei
 Michael S. Palmer
Alg
Audi Original "S" Cars
Mar 31, 2010 03:41 PM
Tourette(AFC2.812v)
Nov 30, 2005 12:40 PM
spdtch
Sep 15, 2005 04:44 PM
180q
Apr 2, 2001 06:48 PM
