Water Meth group buy info
Old Apr 3, 2008 | 07:38 AM
AudiTTboi's Avatar
New Member
Default Water Meth group buy info
This code will give 20% off on all kit orders. bddb4b This coupon will be good for the next 9 days. If someone needs longer have them email me DevilsOwn of his contact us page to make arrangements. Everyone is going to want the 2.5 Bar kit. If you are wanting nozzles other than DO3 and DO5 please put in the notes and we will exchange for you. Dual nozzle guys probley will want the 2 and 5 or 2 and 4 and the signal nozzle guys if they are low modded will use the do3 and the higher hp guys will run the do5 Everyone will need the 2.5 bar controller. http://www.alcohol-injection.com/water-injection-kits-1/universal-19/universal-stage-2-12.html dual nozzle upgrade http://www.alcohol-injection.com/upgrade-45/dual-nozzle-upgrade-200.html<ul><li><a href="http://www.audiforums.com/m_845354/tm.htm">http://www.audiforums.com/m_845354/tm.htm</a</li></ul>
Old Apr 3, 2008 | 10:04 AM
brillianTTdc's Avatar
can someone point me to an explanation as to what the eff this is?
Old Apr 3, 2008 | 11:38 AM
Horch it's Avatar
I'm thinking FMIC method of cooling em down to help heat exchange...summer coming up and all
Old Apr 3, 2008 | 02:49 PM
Russ Scott's Avatar
Default what the eff this is? the short and sweet from Aquamist:
water-injection equipment:
"The main function of these systems
is to suppress detonation caused by
high temperature and pressure developed
within the combustion chamber when
the effective compression ratio has
been taken beyond the auto-ignition point
by either a turbo or a supercharger.
Water, with its high latent heat content,
is extremely effective for controlling
not only the onset of detonation but also the
production of oxides of nitrogen in
the modern leanburn engines"
the concept was developed during WW II to permit ultra high boost in piston driven fighter planes, aka "wartime emergency power"
sound complicated? it is in my experience.. I used it on a normally aspirated high compression 8 liter (502 cu inch Cadillac) to supress detonation while towing
these sytems have come a long way since then, however (digital controls, etc)...
Inject a tightly controlled volume of water in a fine mist, into the air intake stream for detonation control, add alcohol to increase power
it's challenging to tune properly
Old Apr 3, 2008 | 05:36 PM
Wow. That sounds like an extremely difficult solution.
Old Apr 6, 2008 | 07:43 AM
AudiTTboi's Avatar
New Member
Default no! you should really get water meth before the FMIC...
you will see far better results than the FMIC can do..FMIC can help, but w/m fights the heat directly...you also get far better gains in terms of performance...not to mention with my group buy the water/meth is cheaper...your looking at around 80 degrees in cooler temps...FMIC not even close..it also cleans your engine of virtually all carbon deposits...this will extend the life of your engine....FMIC just cools incoming air to near ambient temps
AudiTTboi
Apr 12, 2008 10:02 AM
AudiTTboi
Apr 12, 2008 09:58 AM
ND4SPEED
Oct 10, 2003 01:03 PM
BiZzAro ThAi
Feb 3, 2003 04:26 PM
BiZzAro ThAi
Feb 3, 2003 03:29 PM
