Radio Removal Problem.....please help
Old Apr 3, 2008 | 09:57 AM
1 Mean TT's Avatar
Default Radio Removal Problem.....please help
Ok...got the radio removal tools and the left side just doesn't catch strong enough to pull the radio out. The right side won't come out if I wanted it to and I can pull the right side out slightly, but the left side isn't holding good enough to pull the radio out? ARGH
Old Apr 3, 2008 | 10:00 AM
esanmiguel's Avatar
Are you using home made tool or the real ones? You have the hooks facing the right way?
Old Apr 3, 2008 | 10:03 AM
JustJeff's Avatar
Default push the left side tool in further, then use your pinky-finger or a pick tool in the cassette door..
pull.
the right tool needs to be in place to release the right catch.
you will not be able to remove the right tool, unless you get the H/U out all the way, then push on the tab.
<img src="http://mk1tt.montebellopark.com/images/radiospring.jpg">
Old Apr 3, 2008 | 10:06 AM
1 Mean TT's Avatar
Concert II....no cassete
Old Apr 3, 2008 | 10:07 AM
1 Mean TT's Avatar
yeah, real tools....even went and bought a second set....still no dice
Old Apr 3, 2008 | 10:17 AM
JustJeff's Avatar
try a pick tool in the slot
Old Apr 3, 2008 | 10:20 AM
1 Mean TT's Avatar
I'll try that and post back
Old Apr 3, 2008 | 10:28 AM
Cruzad3r's Avatar
Default is this your first time? if it is, make sure you insert the keys in correctly and pull harder. i had
to apply some force to my stubborn HU when i removed it the first time. after that, it's easy. GL
 Pouria Savadkouei
 Michael S. Palmer
Old Apr 3, 2008 | 10:44 AM
1 Mean TT's Avatar
Default Thank you very much.....that worked.....BRILLIANT!!!
<img src="http://pictureposter.audiworld.com/85812/brilliant.jpg" />
Old Apr 3, 2008 | 10:45 AM
1 Mean TT's Avatar
I got it and yeah....it was my first time
