My Right Xenon headlight doesn't turn on at times. Anyone experience this? -->
Old Apr 4, 2008 | 10:09 AM
fkacct's Avatar
Default My Right Xenon headlight doesn't turn on at times. Anyone experience this? -->
I changed the ballast and that didn't fix the problem. Also checked the socket to bulb connection and no problems...The rest of the headlight works fine at all times....its just the xenon part.
I've noticed that it usually fails to turn on in th mornings. However, once it turns on, it will stay on and it will keep turning on from there after......
thanks
fkacct
Old Apr 4, 2008 | 11:51 AM
JustJeff's Avatar
What "ballast" did you change?
Old Apr 4, 2008 | 11:58 AM
fkacct's Avatar
Default changed the aluminum box on side of the headlight (aka Xenon Controller). Is there....
anything else that control the ignition of the xenon bulb (eg. Igniter)??
Thanks,
fkacct
Old Apr 4, 2008 | 12:03 PM
JustJeff's Avatar
Default that's the 'power supply', the "ignitor" is your problem inside the headlight
<ul><li><a href="https://forums.audiworld.com/tt/msgs/1568541.phtml">'How to' and terms here</a></li></ul>
Old Apr 4, 2008 | 12:13 PM
fkacct's Avatar
Default Jeff, Any way to change this part without taking apart the front lens? Also...
I've got Euro Headlights and I'll be getting this part from my U.S. spec headlights sitting in the garage....Would you happen to know if they're the same?
Old Apr 5, 2008 | 07:04 AM
JustJeff's Avatar
Absolutely not. I assume the ignitors are the same. They can be found on eBay for $50
Omega
Feb 13, 2008 07:45 AM
Bariukas
Apr 16, 2007 07:06 AM
Audi Escargot
Nov 21, 2006 06:21 PM
dascsh
Aug 20, 2006 07:59 PM
