Question... water temp gauge -- sensor install >>
Old Apr 5, 2008 | 06:01 PM
NOLA TT's Avatar
Default Question... water temp gauge -- sensor install >>
Just checking... will this work, screwing into the adaptor, and then connect the wires to my gauge?
<img src="http://images35.fotki.com/v1167/photos/1/1001385/6095465/100_2128-vi.jpg">
If so, then why does this look different?
<img src="http://www.42draftdesigns.com/images/cnc/42hardware/mk4_18t_watertemp4.jpg">
Old Apr 5, 2008 | 06:08 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default In pic #2 you must provide a ground....>>
Through the adapter body, but it looks like it's bolted to metal? Regardless, if your sensor has a Hot and Ground lead you should be good to go..
Old Apr 5, 2008 | 06:10 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Or as an alternative...>>
(with no messy hook-up) The Scangauge will output both Water and intake temps....:-)
<img src="http://images32.fotki.com/v1092/photos/7/7305/6020302/IMG_0430-vi.jpg">
Old Apr 5, 2008 | 06:17 PM
NOLA TT's Avatar
Default So...
If I do what's in pic #1, then am I right that the black ground wire is grounded since the adaptor is bolted in like this?
<img src="http://www.42draftdesigns.com/images/cnc/42hardware/mk4_18t_watertemp5.jpg">
Old Apr 5, 2008 | 06:19 PM
NOLA TT's Avatar
I already have the gauge :-)
Old Apr 5, 2008 | 06:22 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default I think you'll have to provide the ground to the black wire Vince...>>
Depends on what your Gauge wiring diagram shows you as to whether it can be done at the adapter block, or run back to the gauge......
Old Apr 5, 2008 | 06:23 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Just a shamless plug...
Old Apr 5, 2008 | 08:25 PM
1 Mean TT's Avatar
Schwing......just wanted to say that your products are great. I'll get that VTDA eventually.
 Pouria Savadkouei
 Michael S. Palmer
- GT Style -
10
Jul 15, 2014 08:56 AM
rehan1212
Apr 26, 2012 09:48 AM
gmbchef
Dec 20, 2005 06:02 AM
NYC_S
May 24, 2005 07:49 PM
jschick
Audi 100 / A6 (C4 Platform)
May 10, 2004 10:33 PM
