timing belt help please
Slide it on cam gear 1/4" in the marked spot. This leaves a little extra slack.
Go to bottom and slide it on the crank at the marked position - you gotta pull that sucker. Once you get it in position - only slide it on 1/4".
Do the water pump last - you can actually get some leverage to pry it on.
Then slide it on all gears the rest of the way.
Pull the tensioner pin.
Hope that helps a bit!
Sometimes rotating the crank pulley Clockwise as you push the belt on helps. Make sure you don't skip a tooth.
Putting the belt on each pulley just a little way as Randy mentions makes it doable as opposed to seemingly impossible... Then work the belt back onto the pulleys..
