has anyone removed the side rocker panels or installed side skirts?
Old Apr 7, 2008 | 11:19 AM
Audiboy's Avatar
Default has anyone removed the side rocker panels or installed side skirts?
Looking to see what my best options are of adding skirts at the track, and easily taking them off for jack access or everyday driving.
Old Apr 7, 2008 | 11:28 AM
GeTT da NeTT's Avatar
14 bolts hold those on. Plus, you'll ruin the metal plate with TT on it.
Old Apr 7, 2008 | 11:31 AM
Audiboy's Avatar
Default thanks. That will not be an option then. In that case, I'll fab up an aluminum bar
that bolts on to the jack rails and attach the skirts using some wing nuts or something.
Old Apr 7, 2008 | 12:09 PM
maaliish's Avatar
Not true. I took mine off and reused the "TT plate". Not sure how/why it would get ruined.
Old Apr 7, 2008 | 12:10 PM
nikhil's Avatar
just out of curiosity, why are you adding them for track use?
Old Apr 7, 2008 | 12:14 PM
MCPaudiTT - DEFCON 1's Avatar
Tech Guru
Default Details? I have a dent in my rocker panel that I would love to fix - how does it
come off?
Old Apr 7, 2008 | 12:21 PM
Audiboy's Avatar
Default working on aerodynamics to see if I can improve high speed stability
After adding a front damn, the car had amazing front end grip on high speed transitions. Moving to 285's up front made the rear handling at high speed really iffy.
I'm thinking there's enough air getting underneath to lift up the rear even at AutoX speeds.
I'm also trying to see what I can do about rear downforce. I'm trying to take off massive high speed oversteer. I tend to be drifting the car a lot, it slows me down.
Old Apr 7, 2008 | 12:37 PM
It was glued on and got twisted coming off.
 Pouria Savadkouei
 Michael S. Palmer
Old Apr 7, 2008 | 12:41 PM
Default Hi dude. the stuff under the kick plate is obvious, there are 2 wrapped around in the rear wheel
well. then it pulls down from the top.
Not difficult at all, I just F'ed up the kick plate and had to get another one.
It's really obvious in the Bentley.
C
Old Apr 7, 2008 | 12:52 PM
nikhil's Avatar
Default I really want to see your car while I'm out in SF this summer...
and get some auto-x tips!
