2nd and 3rd gear syncros.........R.I.P.
Old Apr 7, 2008 | 10:01 PM
artinmoTTion's Avatar
Default 2nd and 3rd gear syncros.........R.I.P.
<center><img src="http://pictureposter.audiworld.com/51913/clutch.jpg"></center><p>Unfortunately, my TT's tranny is part of the sad class of failing graduates from the Audi transmission program, the one in particular that suffers from 2nd-3rd gear grinding starting at about the 50k warranty mark, with anything more than normal "commuter-speed" shifting.
Like any good TT forum member, I put in the Redline MT-90 at about 50k, hoping for a miracle, which did not happen (helped a little, definitely better than stock fluid), and have basically been gently making that shift for about the last 50k miles.
From the quick phone pic here, you can get a glimpse of the carnage going on right now, that's a shiny new South Bend clutch and flywheel in place, and the rest of the trans is sitting off on a rack. The 2nd and 3rd syncros were in fact toast, and while I would have definitely preferred to have this done under warranty, well, the timing didn't work out that way. FWIW, my $.02 is that transmissions are Audis' weakest (non-electrical) parts.
So, just an FYI for other proud owners of delinquent 2nd-3rd grinders, yours are probably toast as well, but when it's time to surgerize the clutch, when you're already 10 hours' labor deep, might as well spend a few more hours and replace those syncros, they're not getting better by themselves.
Some Motul gear oil going in this time, will give a bit of a review on that in time.
Ahh....carnage!
Old Apr 7, 2008 | 10:38 PM
Horch it's Avatar
Default *plays taps, followed by Happy Days are Here Again*
is that like a stage II clutch?
Old Apr 7, 2008 | 11:07 PM
Default lol, stg 7....
"Let's Go" from the latest and last Ministry disc has been the song of the week over here...definitely a good "motivater".
I think it's stg 3-4, fwiw. Can't wait..
Old Apr 8, 2008 | 03:43 AM
MCPaudiTT - DEFCON 1's Avatar
Tech Guru
Default Are you doing the synchros or having it done? If you, you better be taking pictures! If a shop, ..
how much?
Old Apr 8, 2008 | 04:02 AM
ITALSKIER's Avatar
wow......sorry to hear bout that Rich..........
Old Apr 8, 2008 | 05:03 AM
Scenic Driver's Avatar
Default That sucks
I prefer Motul to Redline FWIW
Old Apr 8, 2008 | 05:20 AM
alms_TT_ny's Avatar
Default I'll probably replace mine when the clutch is out.
I was told expect another $800 to do the synchros while the clutch is apart.
Old Apr 8, 2008 | 05:39 AM
AxeYrCat's Avatar
Member
Default Ack! My stage 3 Spec clutch is interesting enough to drive...
I hear the South Bend ones are a little nicer and have a little more inbetween on and off.
 Pouria Savadkouei
 Michael S. Palmer
Old Apr 8, 2008 | 05:43 AM
SparTTan's Avatar
Default Welcome to the club!
I shudder to think how much that job costs out of warranty... Dealer took 3 weeks to do mine (under warranty, obviously).
2nd-3rd gear grind was my same problem, which first occurred around 25K miles and got progressively worse. Took until about 42K to convince the dealer that there was actually a problem.
Old Apr 8, 2008 | 06:54 AM
Default Re:
2 syncros &amp; associated rings, etc = 1.2k w. trans out.
