DOH!!!!!! Rubbing in the front now... thoughts?
I don't think I'm near as low as a good many people. I measure differently... from the fender to the lower wheel lip and it's at 23". With the Eibachs it sat at 23 3/8. If I measure to the ground like most do I get 25 1/4"... which isn't terribly low (I think russ is 24 1/2 or something). In fact the front height adjustment is almost all the way to the top!
My wheels are 8" ET 32.. so they are sitting inbound about 16.5mm (using spacer calc). Do you think this could be resolved with a spacer? or am I doomed? Should I hammer out the spot where it's rubbing? I can take a picture later tonight or this weekend so you can see the exact spot if that helps.
What are you guys running for height and wheel size/offset and are you getting any rubbing issues?
<OR> Sawzall + Compound hammer FTW!
. doute ur issues the same....
