can someone help me identify this tube?
Old May 30, 2008 | 06:05 PM
sharkaTT's Avatar
Junior Member
Default can someone help me identify this tube?
<center><img src="http://pictureposter.audiworld.com/86540/img_7156.jpg"></center><p>Anyone know what this tube is used for? One end is attached to a braided hose at the bottom of the black round plastic thing in the picture and the end with the rubber tip I have no idea where it goes. In a failed attempt to replace the CTS, I had to moved wire clusters out of the way. As I gave up and started putting everything back in place, I noticed this tube hang or actually pointing up with the rubber end not attached to anything. I was able to start the engine and it ran fine but that was only for a few seconds. I don't want to start driving it tomorrow and have something fail on me because this tube is not in it's proper position. Any help would be appreciated!
Old May 30, 2008 | 06:06 PM
sharkaTT's Avatar
Junior Member
Default a different pic for better perspective...
<center><img src="http://pictureposter.audiworld.com/86540/img_7158.jpg"></center><p>
Old May 30, 2008 | 06:08 PM
TToro 3.2's Avatar
Junior Member
are you talking about the vacuum pump for the manifold?
Old May 30, 2008 | 06:18 PM
sharkaTT's Avatar
Junior Member
Default I think so...sorry but I'm not too knowledgeable about my car
<center><img src="http://pictureposter.audiworld.com/86540/img_7156_red.jpg"></center><p>
New pic attached with the parts I'm talking about in my original post circled in red.
Old May 30, 2008 | 08:27 PM
David_TT225QC's Avatar
Default That probably hooks to a vacuum source on the engine itself. Start by looking at the intake manifold
for a nipple with no hose. That looks like it probably has to do with cold start emissions stuff. You probably wouldn't have a running issue but might throw a code.
Old May 30, 2008 | 08:29 PM
sharkaTT's Avatar
Junior Member
thx! I'll check it tomorrow morning when there's more light out
Old May 30, 2008 | 08:46 PM
Default Just did a little quick reading
If that tube is going to that black round canister type thing then that is the vacuum signal tube for the variable intake solenoid. I was wrong about it being for cold start, apparently is is for tuning power delivery and optimizing fuel efficiency.
So you still should look around the block for a vacuum source but if you don't hook it up, you might not run as well as usual and probably will throw a code.
You should break anything but you do want to find the vacuum source for that sucker.
Old May 30, 2008 | 09:35 PM
sharkaTT's Avatar
Junior Member
thx for the follow-up! i really should pick up a Bentley repair manual...
 Pouria Savadkouei
 Michael S. Palmer
Old May 31, 2008 | 03:24 AM
TTinCT's Avatar
Rest In Peace
Default you should come to TT-East this year...>>>
Bentley has provided a few prizes...you never know, you may win!!!!
Yeah, i know...cheap self promotion...but it seemed timely! ;-)
Old May 31, 2008 | 05:28 AM
sharkaTT's Avatar
Junior Member
Default well...searched again this morning and couldn't find where it goes
It's only a 5-6 inch hose so I searched a 6 inch radius from the vacuum pump looking for an outlet to plug it into...but nothing. I took a quick drive with the hose disconnected and it didn't seem like it had any effect. I guess I'll be ordering my Bentley manual today. Hopefully nothing will break in the next 4-5 days until it gets here. I hope when I get the manual, I'll be able to help someone else on the forum.
