just got back from my road trip to my lake house... had some minor issuies >
Old May 31, 2008 | 05:22 PM
TTwizted13StrtRcr's Avatar
Member
Default just got back from my road trip to my lake house... had some minor issuies >
i had thought i tuned my TT correctly with the boost machine.. but appearantly not
i tested it in 3rd and 4th gear, from 3-4k rpm
i got a steady pull of 17/18lbs of boost... but during the road trip, when i tried holding it and accelerating upward. around 4500 rpm it just jerks, and drops to 10lbs of boost
what is this due to, and how can i fix it?
thanks guys
my boost machine >> pressure relief valve (left) is turned 1 and 3/4 and my regulator (right) is turned 5 and 3/4 turns
Old May 31, 2008 | 05:28 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default 2 things......>
!) Maf may be marginal
2) boost too high
Stock chip (as discussed before) can't take morethan a few PSI increase...A week MAF will exhibit those characteristics (boost pullback) becaue it's output has degraded over time..
Old May 31, 2008 | 05:30 PM
Member
so suggesting i reduce boost, and get a new MAF sensor?
Old May 31, 2008 | 05:35 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
How old's the MAF?
Old May 31, 2008 | 05:36 PM
Member
Default im guessing the original. i bought the car used 6 months ago.
its a 2002 225Q
Old May 31, 2008 | 05:39 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Yup......You're probably due then..>>
They can last anywhere from 20K to 80K but gradually decay over time as the measuring surface degrades...Time for a new one!
Especially with the ****, it needs t be operating at 100%
Old May 31, 2008 | 05:45 PM
Member
Default will do that this week.
thanks again for the insight steve.
your like the audi know it all god. LOL
Old May 31, 2008 | 06:46 PM
PracTTical's Avatar
Default i'm chipped and see that kinda PSI.. lower boost, you've probably toasted your MAF...
time to upgrade
 Pouria Savadkouei
 Michael S. Palmer
petervan
Oct 16, 2005 07:46 AM
leosphere
Aug 18, 2005 01:48 PM
X-Pwred225
22
May 12, 2005 01:55 AM
Tongpo~Dr. Evil
9
Mar 22, 2004 11:48 AM
