Timing pull!
Old May 31, 2008 | 06:49 PM
dfminc's Avatar
New Member
Default Timing pull!
I have a 225 and recently received a vag-com. I was playing around with my new toy and I realized I was getting up to 8 degrees of timing pull in the upper rev range. That seems like unusually aggressive for stock programming to me. Anyone have any idea whats up?
No codes, running well, logged done on a cool morning shortly after startup so iat's should have been low, 91 octane cali gas....
Old May 31, 2008 | 07:07 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default Depends on a lot of thngs...>>
MAF health, Gas quality, Boost levels, Temp sensors, IAT's
Here one of my charts..(after Manifold insulators dropped IAT's)
<img src="http://images25.fotki.com/v950/photos/7/7305/137712/timing-vi.jpg">
Old May 31, 2008 | 07:14 PM
dfminc's Avatar
New Member
Default So are you saying 8 degrees is ok? or that I should look into each of those....
The MAF was within spec when I checked, 91 octane used, stock boost, no heat soak or high outside temperature
Old May 31, 2008 | 07:18 PM
TTschwing's Avatar
AudiWorld Uber User
Tech Guru
Default It is what it is...>>>
If all sensors are operating correctly and at 100% the ECU makes the determination as to the amount of advance the engine can utilize....
Log 3 Blocks (at once) 002, 118 and 204
2K then WOT to redline in 3rd gear. Email me the log and I'll take a look for any potential problems....
Old May 31, 2008 | 07:23 PM
dfminc's Avatar
New Member
Default Ok thanks...
I was a little worried because I was reading about advancing timing and the write-up said when pull got to 6 degrees it was time to stop and I was above that stock.
Old May 31, 2008 | 07:24 PM
mad scientist's Avatar
Junior Member
Default sounds familiar
When my car was stock (225) I noted similar timing pull on a warm engine, 91 oct, 60-70 degF ambient, 30-35 degC IAT, WOT.
For higher ambients timing pull started at lower rpms.
myfootsmells
62
May 27, 2005 02:53 PM
Pop3
23
Mar 30, 2005 07:00 PM
RobC
11
Jul 20, 2004 07:39 PM
Swank4
Jul 20, 2004 11:51 AM
LCP
49
Jun 10, 2003 01:40 PM
