Defcon Questions>
Has anyone tried both setups? What did you think of them? Anyone rockin' the combo I'm thinking about getting? I know John posted something about not liking the urethane either... Will keeping the urethane be a good idea because I'm getting a haldex orange this summer? I know this will give my car more of a feel from the rear... right now it is WAY Too light back there (there isn't anything back there at all. I feel like I need to add a subwoofer setup lol.
It's just that my car doesn't drive right since I put these larger wheels on & I'm not enjoying that. Currently the rear just seems to WAG it's tail a lot after turns. It needs to be stiffened up big time! Maybe it's time to make these custom sway bar links out of metal I have been talking about for months! And get my shocks/springs stiffer...
Go with the Blue for street use, only difference is it disengages the LSC on decel. Works the same as orange in every other way.
BTW, going by your mods in your sig, you might try taking your rear sway off the stiff setting to get the rear to settle. Alignment/tire pressure first, like mentioned, but this might be your next option.
Most of your problems are probably alignment related.
Skip the orange controller
H&R 21mm rear (stiff)
38psi tire pressure all-around (digital gauge, just did last weekend)
defcon 1
going to get another alignment I guess when I get front spacers and my height setup 100%
On the rear bar being set to soft, I feel like I want the rear tighter, I feel like it trails the car a lot, but none the less I'm going to slide under today and swap it to soft.
Right now I'm going to pressure test the car & instal my new IAT : )
I will post up results when I'm all done
MK2 arms with defcon, MK1 (rubber) front (D2), MK2 bush rear; 225/40/18 PS2's - loved this setup, ran tight and sharp.
Ran MK2 with defcon, poly fronts (D1), worn MK2 bushes rear; 225/40/18 PS2's, but only ran this about two weeks - wasn't real impressed with any improvement from the poly fronts at the time, but as I say, didn't run it for very long.
Currently MK2 with defcon, poly fronts (D1), MK1 bushes rear; 245/35/18 PS2's - not sure yet about this, maybe more slop from the wider tires (they're broken in now with about 2000 miles on them), maybe the polys, maybe the MK1 rears.
I might put polys in the rear - they're on the shelf now, and I might go back to rubber (MK1) bushes in the front.
I have a Neuspeed 28mm rear bar on middle setting and run 38 psi F/R
Still, we're comparing apples and oranges - I have FWD and no spoiler, corner-balanced and fresh alignment - but bottom line is though, the rear seems a bit looser to me as well.
You need a little give, so the tires can grab the road with all the dynamic movement going on. Everything rock solid is going to make for a ride like this: http://myspacetv.com/index.cfm?fuseaction=vids.individual&videoid=3 5012323
