what are the widest wheels you can run on a tt225
Old Jun 2, 2008 | 05:21 PM
blktt92's Avatar
Old Jun 2, 2008 | 05:41 PM
Basttion's Avatar
'bout
Old Jun 2, 2008 | 05:44 PM
TTinCT's Avatar
Rest In Peace
one-dy
Old Jun 2, 2008 | 06:02 PM
N9909E's Avatar
Junior Member
This .................................................. ........................................wide.
Old Jun 2, 2008 | 06:06 PM
XCLR8TT's Avatar
Senior Member
But............only.............with............s. ...p....a....c....e....r....s
Old Jun 2, 2008 | 06:12 PM
MoneyShifTT's Avatar
Member
tree
Old Jun 2, 2008 | 07:12 PM
furiousgeorge's Avatar
What screen resolution do I use to accurately measure that?
Old Jun 3, 2008 | 12:06 AM
Russ Scott's Avatar
Default I believe 9's and 11's, front and back
it depends on your preference for "poke" and your tolerance to rub ... at those widths you'll probably have a good deal of both
If you want a clean fit and no worries, so you can really DRIVE the car...
8 1/2's and 9 1/2's work well
10's on the back of my car took quite a bit of modding of spring perches, inner fender panels, and shock mounts to clear... but I wanted <i>no</i> poke
In the big widths, 19's have less clearance problems on the inside, especially in back
 Pouria Savadkouei
 Michael S. Palmer
Old Jun 3, 2008 | 07:30 AM
sonus's Avatar
Default Russ is right, altho if you don't want a staggered setup and you want wide wheels,
an option is to go 9" all around and if you are doing custom 3 multipiece wheels, have them stagger the offsets so you get the flush look without running spacers. Since TT's aren't rear wheel drive, this makes the most sense from a purely handling perspective yet it still gives you the aesthetics of a staggered wide wheel setup.
Old Jun 3, 2008 | 09:51 AM
Russ Scott's Avatar
sonus, you nailed it with your set up, looks fantastic!
flyin8
Jul 17, 2006 06:48 AM
VenTTed
18
May 4, 2005 03:20 PM
red4kcsq
Mar 9, 2005 07:46 AM
Silver225TTAnnapolis
Dec 16, 2004 12:05 PM
01blackS4
10
Feb 10, 2004 04:32 PM
